2 or 6 pin window motors?
Both of the window regualtor motors have failed and need replacing, my mechanic has said that enault will charge £180 + VAT per unit new or i can source my own for him to fit. I have located motors via Ebay but am not sure if the 2 pin or 6 pin unit is correct. I have a 2005 3 door. Anyone know what the correct OEM unit is?
- busternlouie
Re: 2 or 6 pin window motors?
Do your windows have the "one touch" function, ie do they rise and lower on their own after only a short press of the button? If so then you require the 6 pin motors.
If you have to keep the button pressed for the duration of the window movement then you require the 2 pin motors.
