Panaramic sunroof
waity2004
Currently Drives:: Megane 1.9DCI 3dr
Re: Panaramic sunroof
Postby waity2004 » Fri Aug 27, 2010 10:01 pm
Hi all,
I have had the problem when travelling at speed the wind coming in through the sunroof so i investigated the problem.
I exstened the sunroof fully open where the tourque srews are now visible when overlapping the rear sunroof, i took both screws out and the 2 brackets that are attached are connected with rubber runners to run along the runners underneath, i removed them both and they were badly worn making them loose inside causing room for the to move aboout, replace the from going to a dearler...Problem solved
eddiemcgarrigle
Currently Drives:: Megane II 1.9 DCi
Postby eddiemcgarrigle » Mon Sep 06, 2010 9:25 pm
I have to agree.
The rattle and wind ingress from my sunroof has been driving me crazy so I undid both screws and took a look at the sliders. The rubber pads on both sides where badly worn and not giving a tight fit which leads to my irritating problem of rattles and wind noise.
Does anyone know the part numbers for the rubber pads or does the sliding mechanism come as a complete part? Part numbers and prices please.
55 Plate Dynamique Pearl Black 1.9 DCi, 130 bhp
hoggies
Currently Drives:: 2009 Yamaha FJR1300 AS
2005 Megane II 1.6vvt Privilege Auto estate .
Postby hoggies » Fri Nov 05, 2010 4:45 pm
Just driven down through France in my new (to me) 2005 Megane 1.6 vvt auto estate, and the wind roar from the panoramic sunroof was horrendous.
A combination of Autoroute speeds (90 mph) and a force 8 gale exacerbated the problem, because at 'normal' speeds it's ok.
I've read this thread with interest, and it seems to be a fairly common condition.
I've had a look, and I think it's the rubber seals which are the problem - particurlarly the front one, it's partially compressed in the centre, and is quite stiff and is not very flexible.
So, like the previous poster, I would like to know if you can buy these seals, and if they are a DIY or a dealer job? (and if anyone has anyideas as to cost - either DIY or dealer?) Oh, and how to do it - DIY !
Very grateful for any help with this.
2005 Megane II 1.6 vvt Privilege Auto estate
neilbrumie
Currently Drives:: megane oasis 1.5dci
Postby neilbrumie » Thu Nov 25, 2010 7:48 am
Had the usual panaramic roof rattle,greasing rear slide pivots worked for a few days,eventually cured mine by removing the sliding glass rear pivots ( torx screw ),making a couple of thin plastic sheet washers,put these either side of the pivot bracket ( with grease ) (making sure the pivot pivots with no friction ) roof works great and no rattles at all ;) Hope this helps anyone.
stevefire
Postby stevefire » Wed Apr 06, 2011 8:02 am
Can someone supply the part numbers of the running sliders of the Sunroof??
I cannot find anything on the internet. went to the local dealer and he said i have to buy the whole sunroof mechanism!!!!!! around 600 euros.!!
rossco87
Currently Drives:: Megane II Phase II Dynamique DCI
Replacing Rubbers?!
Postby rossco87 » Mon Aug 08, 2011 10:34 am
it could be that the rubber runners have perished..... i have had this problem.... local dealer was £98 for replacement brackets and rubbers!
Anybody know a quick and simple way to get the runners apart?
rossco87
Postby rossco87 » Tue Aug 09, 2011 10:54 am
stevefire wrote:Can someone supply the part numbers of the running sliders of the Sunroof??
That's a lie! I don't know the part number, but the sliders and riser brackets are £97.31 (includes VAT) from renault dealer
hammy100
Postby hammy100 » Sun Mar 31, 2013 4:13 pm
:cry hi i have 03 dynamic 1.5 wind comes under sun roof at 65/70 any thoughts on how to fix problem
