Will Not Start - Engine Turning Over OK - 1.9DCI
- Currently Drives:: Black 2004 Renault Megane CC Privilege
Re: Will Not Start - Engine Turning Over OK - 1.9DCI
I'm hoping maybe you guys can help me as well. I'm having a similar problem after my car ran out of fuel. I've found the priming pump and I was trying to squeeze it earlier, but it didn't seem to be doing anything. How long will I need to do this for? Should the priming bulb feel fully inflated or feel deflated?
2004 Renault Megane CC Privilege 1.9DCI.
Pump it till it feels firm then pump a bit more , you will see the fuel in the clear pipe
Thanks. Does anything need done to the priming pump before I start squeezing it? Or can I just access it and begin as is?
"as is", as you wrote... There are two valves in the priming bulb. Help them work by squeezing and releasing it quickly. You will also need to have diesel in the tank...
- Currently Drives:: 2006 Megane 11 1.9dci Sedan
2006 Citroen 2.0VTS Coupe
Very Helpful
my car does the same, Yet how do you detect these micro leaks? when I pump my primer the air wont budge.
Users browsing this forum: Google [Bot] and 51 guests
