Wiper problem!!
Gav
Postby Gav » Wed Dec 05, 2007 12:56 pm
AlexB wrote:The following "or once when i role the timer stalk with the numbers 1-4 wrote on" does not happen in my car.
I get this happening only when I increment the stalk thingy, not decrementing. I wonder if there's a fault and the wipers therefore also move when decrementing. Perhaps take it to a friendly Renault main dealer to check the original spec, and if the current operation is correct.
Mrs J
Re: Wiper problem!!
Postby Mrs J » Sun Jul 20, 2008 10:12 pm
Interestingly I am also having the same problem with my Dynamique DCi 120 2003. When I first got the car the auto wipers worked perfectly fine, but now they only work for one wipe when I move the stalk or turn the mechanism on the end of the stalk - this basically means that the auto wipers are not auto wiping! :roll: (this is just one of many problems with my Megane).
The auto lights do actually still work though (boy, it feels gooood to say something positive about the car), and so from reading the posts on this subject I am thinking that the problem must not lie with the sensor but somewhere else :?: ?? I have also just acquired a new fault on my megane (ooo the excitement), where I turn the rear washer on and the wash comes out on the front windscreen instead...but the rear wiper still cleverly knows it needs to wipe, even with no wash!! :hmm Any ideas???
I'm wondering if my electrical problems may have the same cause. In addition to the above, the passenger side window isn't working at all (tried resetting), the boot pops open randomly when I'm driving, and the lights on the dashboard/radio/clock sometimes just turn off briefly (I'm hoping that the brakes and power steering aren't affected when this happens, as it looks like an electronic failure). Any help or advice that could be offered are much appreciated!
I'm not sure why I have still got the car...well I do - I love driving it, and without allllll the electrical problems I have had, there is a good car in there somewhere!
hyke
Currently Drives:: scenic
Re: Wiper problem!!
Postby hyke » Wed Jul 23, 2008 8:03 pm
i am pretty sure that it is a rainsensor problem as this is quite common, it is located above your interior mirror (be carefull with the covers)
Jonault
Re: Wiper problem!!
Postby Jonault » Thu Jul 24, 2008 1:12 pm
Mrs J - There is only one washer pump which rotates one way for the front windscreen and the other way for the rear screen. You might have a wiring fault or you might need a new pump, sorry I can't be of any more help on that fault.
