Improved roadgrip
tallpaul
Re: Improved roadgrip
Postby tallpaul » Wed Jul 08, 2009 5:20 pm
did anyone fit this rear ARB? there's a 07 scenic in my local breakers with a front ARB on, i'm toying with getting it if its straight, its a petrol if that makes a difference??
R55VYS
Re:
Postby R55VYS » Fri Jul 10, 2009 8:11 am
Oliver wrote:
R55VYS wrote:Buy some sports dampers if you've only got springs on, that would make a big difference.
O.K. boy, I have these progressive springs only at rear in mine (front is still OEM):
https://www.mad-suspension.co.uk/progressive.htm
They don´t lower (I think they lift abaout 10mm) but they are harder...so do you really think sport dampers are a good choice? I have a nearly new pair of dampers of a ScenicII, I will try them by time.
Only justy noticed this reply 2yr down the line, i wasnt talking to you in the first place with your bodge-it springs, i was talking to steel, obviously if anyone has uprated springs, uprated dampers/shocks are a good idea, as when you change your springs they dont use the standard dampers as intended, why else would they sell them, goon.
Re: Re:
Postby Paddy » Sat Jul 11, 2009 8:35 pm
calm down ladies!
