Cruise Control
Re: Cruise Control
Postby joeishmather » Tue Mar 15, 2011 3:01 pm
How much did you pay for the parts?
Cheapest I've found is £34
shadowswan
Re: Cruise Control
Postby shadowswan » Tue Mar 15, 2011 10:16 pm
joeishmather wrote:How much did you pay for the parts?
Gonna pick them up when I do it, where you get them from?
Re: Cruise Control
Postby joeishmather » Wed Mar 16, 2011 8:53 am
I contacted Renault parts direct, which with slight discount came to about £42 and Renault parts wearhouse or something that was £34ish..
My local Renault will, i think price match if there more expensive so I think I'll get them from there.
Also I'm thinking I may try using another stereo control for the controls, cheaper!lol
But I do like the look of the one you ordered so I'm quite tempted...
Re: Cruise Control
Postby joeishmather » Wed Mar 16, 2011 3:26 pm
Been reading thru this again n I understand most of it,
900ohm for resume button
270 for + button
100 for - button,
Now are all these buttons connected in series to one wire?
And which are the wires behind the steering wheel to connect to? And what connects to them,
Thank you,
Also
Shadowswan, bought all the parts from Renault today, well ordered them... £31.50 total,
Resistors were 13p!!lol
Just need to get the control
shadowswan
Re:
Postby shadowswan » Wed Mar 16, 2011 3:36 pm
kmarty wrote:I did cruise control in accordance to spanish site (shown above) and it works :-). Only what you need is one switch (cruise control/0/speed limiter), four buttons (+,-,recall and 0) and three resistors (100ohm, 270ohm and 900ohm(82ohm+820ohm respectivelly) - values taken from Dialogys):
kmarty wrote:Wires along with connector for CC/SL switch is under this plate:
(picture is from spanish forum)
You must change it like this:
Under plastic bonnet it is this:
You should find the white connector with five wires not conected to anything. This is connector for CC/SL switch. If you find it, you have almost won (unfortunately I heard that some Megane's have not CC/SL wiring preparation so search it before you begin any step about CC/SL.
Will get details for clip under steering wheel later - going to plan it all out on paper if I am going to make a guide, still a little scared but doesn't look too hard...
Re: Cruise Control
Postby joeishmather » Wed Mar 16, 2011 4:00 pm
Thanks, I'm non the wiser tho! Lol
I think I'll wait for your guide!
shadowswan
Re: Cruise Control
Postby shadowswan » Thu Mar 17, 2011 1:08 pm
Can anyone who has done this give me any advice on how to wire the cables under the steering wheel. Other than that I think I understand it all fine...
Which end goes to which cable?
Other than that I think the need is to
Install switch at drivers knee, which is just pull old switch off add switch
Then wire controller, so four buttons
+ wired to 270ohm
- wired to 100ohm
Recall Wired to 900ohm
Cancel wired to straight
one end of each of these wired to a switch and the other ends all wired together
Then the other ends of all the switches wired together
So that leaves 2 wires, one with the resistors before the switches and one after the switches
I'm guessing its these two wires that connect to the block under the steering wheel, to the two wires that are in their own row? Which wire to which of these?
That should then complete what is needed? Unless you want the screen of course for which you need either a renault clip or take it to a garage and pay someone £85 to do it...
Can anyone confirm that this is correct and answer the other few questions?
kmarty
Re: Cruise Control
Postby kmarty » Thu Mar 17, 2011 2:06 pm
shadowswan wrote:I'm guessing its these two wires that connect to the block under the steering wheel, to the two wires that are in their own row?
Yes. But carefully, wires in second row are for airbag.
shadowswan wrote:Which wire to which of these?
It doesn't matter. Same as rezistor pinout.
MEGΛNE Expression Grand Tour/Grandtour/Estate/Tourer 1.6 automat - 2005
sorry for my poor english
Image (Image)
Re: Cruise Control
Postby joeishmather » Thu Mar 17, 2011 2:11 pm
https://babelfish.yahoo.com/translate_ur ... =Translate
Dnno if this is of anyhelp, still not clear on which wires to connect to...
kmarty
Re: Cruise Control
Postby kmarty » Thu Mar 17, 2011 3:09 pm
You connect it here.
And which one to which one, it does not matter. Your set of four buttons and three resistors have no polarity.
Image (Image)
Re: Cruise Control
Postby joeishmather » Thu Mar 17, 2011 3:32 pm
Re: Cruise Control
Postby joeishmather » Thu Mar 17, 2011 3:39 pm
kmarty, thank you i think i understand now!
Re: Cruise Control
Postby joeishmather » Thu Mar 17, 2011 3:56 pm
i did the wrong diagram here, so its been removed and is on next page!
:cool:
kmarty
Re: Cruise Control
Postby kmarty » Thu Mar 17, 2011 3:57 pm
Exactly.
But you have wrong labels of buttons. It should be:
100Ω for "-"
900Ω for "Recall"
270Ω for "+"
0Ω for "Cancel"
Image (Image)
shadowswan
Re: Cruise Control
Postby shadowswan » Thu Mar 17, 2011 4:04 pm
Like that?
