Hi
Does anyone know how to change the standard Air filter on a 05 plate Megane II
The filter housing looks extremely hard to remove, is this the case?
Thanks in advance
Paul
Standard Air Filter replacment
- Ray
- Site Admin
Re: Standard Air Filter replacment
no. do a search. it might be in faq. else mods. its pretty easy. just 2 screws i think
Undo the 2 cross head screws the top piece lifts straight out to reveal the filter
Try an ITG panel filter much better and lifetime usage
Steve
Steve
- Boomstyliemikey
Have you done it yet? I just done mine today. Its behind the battery. There are to screws on either side of it. Undo these with a really short screw drive and pull it up towards the bonnet. Its easy once u know what ur doing
- limraaaah
- Currently Drives:: Renault Megane II, 1.6 16v 3DR.
Tried fitting a new air filter yesterday, no luck! Had the old one loose but there was no room to get it out. It was a struggle to say the least!
Once all the screws are out how do you go about getting the airbox out? Im replacing the whole thing.
Its a 05 Megane II
Its a 05 Megane II
- Anthony
- Rally Driver
To remove the entire airbox assembly requires the battery, battery tray and ECU removing before it is accessible.
