Alright, im just about to swap my discs over, just wondering if anyone has done it before on here, and if so, did you need to replace your abs ring? or was it easy enough to get off the old ones without breaking it?
ABS ring - Rear discs
Re: ABS ring - Rear discs
hi mate,i did my rear discs+pads a while ago,and yes i had to take the old abs rings off to go on the new ones..it was a piece of cake getting them off. they`re not the older style toothed cast rings which are pressed on,they`re more of a flat disc type which are much easier to remove with a little prising..and mine just tapped back on,obviously gently. don`t worry,all will become clear when you get the brake discs off and look at it.
you will need also a high temp glue to place the ring in place and make sure it doenst fell off...
tomalamix wrote:you will need also a high temp glue to place the ring in place and make sure it doenst fell off...
did`nt need to use any on mine,they were a good fit going back on..
suppose it could depend on the brand of discs used though
Hello everyone, this is my first post on here and i dont suppose it will bemy last. Thanks by the way for this fantastic site as all the advise you have given has been spot on with regards to the problem i had.
My issue is now solved and i think its a new one.
i had changed the front and rear discs and pads on my 2004 Megane 2.0. after i had changed everything i took it for a test drive and whilst braking i got a horrible, what i thought was a grinding noise coming from the front of the car. it wasn't grinding it was the abs trying to come on. after a few miles the abs warning light, service light, stop light, and rear brake pad light all came on at once. you can imagine my horror but after looking on here and speaking to a renault mechanic i have solved the problem.
i was told it could be the front abs ring but after putting it on a snapon diagnostics machine it came up with a rear left sensor fault.
i removed the rear left wheel and caliper and rear disc and it turned out that the new disc had blue grease on the abs ring which i believe had come from the new wheel bearing. i gave it all agood clean, put it back together and hay presto problem solved.
thanks again for all your posts and advise. Ian.
Users browsing this forum: Google [Bot] and 47 guests
