"Check Injection" DCi 1.9.
bcm
Currently Drives:: 2003 Megane 1.9DCi Dynamique 120 5dr
Postby bcm » Wed Jun 09, 2010 7:44 pm
Ok, I've got a 1.9DCi 120 and the Check Injectors message appears on the dash constant, checked the site for the same problems but the search isn't working for me! So found as much info as possible!
It doesn't matter whether its cold, warm, first start or been running for ages, tried running it to temp then switching it off then on, still the message appears, any ideas as I'm new to Renault and don't have any diag equipment.
Thanks!
southleigh
Currently Drives:: Megane II Privilege+ 1.9DCi
Re: "Check Injection" DCi 1.9.
Postby southleigh » Thu Jun 10, 2010 7:43 am
hi bcm
I had the same problem with our 54 plate 1.9 DCi 120 and as advised by a previous thread on this topic, I changed the glow plugs. I can't guarantee that's the only solution or that it'll work for you but it did the trick for me.
I can't find the thread at the moment as like you I can't get the search to work!
Cheers,
nickbell69
Postby nickbell69 » Thu Jun 10, 2010 12:40 pm
Yeah i too had that, changed the glow plugs(approx£30 for 4) and problem sorted.
Just be aware if you change them yourself(easy job) the light takes a good 5 minute run before it goes out.
Nick
Users browsing this forum: No registered users and 73 guests
