Brake problem
utkarshc
Currently Drives:: Megane 1.6 Dynamic, saloon, 2008
Brake problem
Postby utkarshc » Thu Feb 18, 2010 1:17 pm
Hello ,
I have a megane 1.6 dynamic 2008 model. Recently i noticed that the brakes were making noise specially when applied at low speed and corners. I went to the service center and they told that the brake pad and disc have to be replaced. They did this and after a few days i noticed that the sound is still there. I asked them about the problem and i was told that it is a common problem in megane and it cannot be rectified. I am quite surprised as earlier i had driven the car for around 55000 Km and i did not get such a sound.
is it true that there is such a problem with megane.
Thanks to replies in advance.
direstraits
Laguna III Ph2 Exception
Re: Brake problem
Postby direstraits » Thu Feb 18, 2010 1:32 pm
It can and it must be rectified by the garage that has performed the service. They haven't cleaned the discs and calipers properly.
Re: Brake problem
Postby davelowe » Thu Feb 18, 2010 3:12 pm
This is a well known issue if they are squealing. Some copper paste behind the pads may be a solution.
Your car should be in warranty. It should be fixed by the dealer.
utkarshc
Re: Brake problem
Postby utkarshc » Sat Feb 20, 2010 6:15 am
Yeah its in warranty,
So it means that it can be rectified. I will ask the dealer the next time i put it in for service.
Thanks for the reply.
Users browsing this forum: No registered users and 195 guests
