Apologies if this is already on the forum.
I don't want to replace the front door speakers, so sound quality aside, are there any simple tried and tested ways of reducing the vibration noises from the front speaker covers, door cards and handles with low frequency bass?
How can front speaker vibration be cured?
- Currently Drives:: Megane 1.6 Sport Hatch
Re: How can front speaker vibration be cured?
How about sticking that dynamat stuff in the door skins, where the handle screws on & a ring around where the speaker screws in.
The best cure for vibrations in the foam that comes on a roll....
You can by 2cm width buy 10m for a few quid...
You stick it all around where the door card meets door... or speaker meets door card...
It is soft enough to allow you to put all back in place and absorbent enough to deal with most vibrations....
The pioneers come with a strip of it each that you stick to them round the circumference then install... No vibrations at all.
Like this for example,
http://www.tapes-direct.co.uk/index.php?main_page=product_info&products_id=960
Double side adhesive type is not advised. You just want the single sided stuff.
Thanks for the advice, will give it a try.
- ICEMAN
- Currently Drives:: Renault Megane II 1.5DCi + Lexus RX 300
perrythebaxter wrote:Apologies if this is already on the forum.
yes:
Dont turn your system up so loud! Simple, Problem solved!!
i dont think you can get noticable vibration in your door cards from the standard speaker! what you would get is noticable distortion from the speaker!!
Yea good point lad.
