Ipod connection with CD changer
Disco_Stu
Currently Drives:: Renault Megane sporthatch
Postby Disco_Stu » Mon Jun 08, 2009 4:24 pm
Hi, I have an in dash cd changer and want to connect my ipod up
I know that Dension do a CD changer retention kit for their gateway ipod kits, however i cant get ahold of one for love nor money! :banghead
Are there any other ways to do this? I've been hunting around for weeks, even got an fm modulator but the aerial connections are different and I cant be bothered changing them if I manage to find a better way to do it.
I'm sick of using an fm transmitter! still want my cd changer connected but if it comes to it i might resort to just having it unplugged :sad
any help would be much appreciated, my apologies if this has already been asked, I didnt spot it
Lifes too short to go slow
08 1.6 Dynamique
Starman
Currently Drives:: Proton 1.6 Lxi Wira
Re: Ipod connection with CD changer
Postby Starman » Thu Jul 09, 2009 9:42 pm
Hi there.
What is your HU? Is it Tuner list or Update list? If it is Update list (says on front of unit), you can get a seperate cable that plugs in the back. It clips with an existing connector (stalk controls I think). This lead has a small jack plug to be able to plug in your ipod. To activate it on the HU, press and hold the "expert" side of the control. Then scroll through the menu til it says AUX OFF. Change to AUX ON, job done! Then, when you plug in your ipod, if it doesn't change automatically (haven't seen what it does), use your sorce buttons to scroll to AUX, the same as you would for changing between cd/tuner, etc.
:idea If you want one, I might be able to get you one. I think they're about £15! Can't remember exactly... :!:
Hope that helps... :wink:
J. :cool:
Disco_Stu
Postby Disco_Stu » Wed Aug 12, 2009 11:08 pm
mate that sounds brilliant, does that still work with cd changer then?
how do i tell what headunit i have? it doesnt say on it.
If you can get your hands on one or tell me where to get one I'd be very interested
stuart
08 1.6 Dynamique
sum-megane
Postby sum-megane » Thu Aug 13, 2009 9:58 pm
Mate I am quite interested to know which cable I need for my update list....
cheers,
Disco_Stu
Postby Disco_Stu » Fri Aug 14, 2009 9:24 am
Discovered this thread viewtopic.php?f=12&t=5873
bumpy macaroon cheers again!
08 1.6 Dynamique
Users browsing this forum: Google Adsense [Bot] and 12 guests
