Rain sensors on front windscreen
Good morning, please bear with me if this question has been asked before but I have just purchased a 2003 3 door 1.9DCI Dynamique Renault Megane. Unfortunately the front windscreen has been damaged and needs replacing. Would someone be able to confirm for me whether or not my particular model has rain sensors thank you. Tim
- anth_dci
- Currently Drives:: Megane II DCi 120 Dynamique 52 plate
Re: Rain sensors on front windscreen
My 52 (03 car) dynamique has rain sensors so i presume yours will too
Thank you for your help.
Of you have a mirror that has a casing raround it at the window. You have the sensor.
If the mirror is just stuck to the glass you dont.
if you have auto wipers,you`ll prob also have to replace the sensor too, as when it`s removed from the old screen the pad that holds it on will stay on the old screen,and the sensor won`t work on the new screen without it. and you can`t buy just the pad,it comes with the sensor.i found out the hard way
