Do you think I am getting a good deal?
£200 to fit and supply brake pads for front and rear?
Re: Do you think I am getting a good deal?
Sounds a little high to me, cant be more than 2 hours labour.
So say £50 per hour at most...
Thats £100 labour and pads for £100
Dont know if that helps
- anth_dci
- Currently Drives:: Megane II DCi 120 Dynamique 52 plate
sounds about right to me to be honest.
£53.26 front pads £43.49 rear pads
£38.80 for labour for rear and another £38.80 for front.
Total with vat is £200.49
- busternlouie
Those pads are pretty dear. Can you not supply your own to be fitted, should be able to get them cheaper than that?
- Currently Drives:: Megane 1.5dci 53 Plate
i got genuine renault disks and pads for front and rear inc fitting was only £250 so £200 just for pads seems expensive to me unless its at a stealership then i guess thats cheap
- anth_dci
depends on what pads are being fitted? cheapo ones you can pick up for less than 20quid a set. get some ferodo 2500 and your looking at 85quid for the fronts from deamon tweeks
apparently genuine Renault parts.
Users browsing this forum: Google [Bot] and 15 guests
