Hi Y'all
Does anyone know what the new and minimum rear brake disc thickness is for the 2005 1.5dci Sports Tourer?
minimum brake disc thickness??
- Currently Drives:: 2005 Megane Tourer 1.5 dci
If it's got pistons or breasts it's going to be expensive!
- DJC013
- Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Re: minimum brake disc thickness??
Hello, in my Haynes manual for my 2004 Scenic 1.9 dCi, they quote New discs at 8.0mm and Minimum thickness at 6.5mm, hope this helps, regards Damian.
2004 Scenic 1.9 dCi 120 Dynamique 6 Speed Black 17" Nervasports VF1 JMRG
Visit my Flickr site ! - http://www.flickr.com/photos/28464546@N05/
Many thanks but the disc appears to be greater than 8mm originally.
- DJC013
bobbyb1288 wrote:Many thanks but the disc appears to be greater than 8mm originally.
Sorry about that, may be different for a Meg, regards Damian.
- A13XDT
https://www.renault.co.uk/Resources/PDF/ ... ins_UK.pdf
2nd page of the pdf has got the car, brake disc diameter and thickness.
Alex
Alex
Cheers Alex, just what I'm looking for. Bought the car from a dealer who sold me the car with rear discs at 8.15mm. They're going to replace them or I won't be happy. Will keep you posted if you're interested. Rob.
They are 270mm diameter which means their minimum thickness is 9mm.
i have a 53 plate megane 1.6 16v looking at changing me rear disks and bearing would disks measuring 270mm x 10mm fit me car? there from a sports tourer 1.5dci on a 05 plate
- pw981
- Rally Driver
from memory, all Megane II saloon and hatch have 240mm rear discs, the sport tourers and scenics have larger rear discs.
2004 Megane II 1.9dCi
Sports Tourer has 270mm Diameter disc rotors, yours has 240mm so they wont fit. Might be possible to swap the calipers over assuming bolt mounting pitch is the same.
Users browsing this forum: No registered users and 82 guests
