Hi I'm new on here. This is my first Megan but I have also owned a Grand Scenic for 3 years too. My car is a 1.6 05 Dynamice. Right on to the problem, last day of my holiday and I was sat in the car and thought I would clean the cigar lighter, hey presto I shorted it out and blew a fuse. So I looked up the lighter fuse in the book and ok, I'll change that and everything would be fine, but no. I found a 20A fuse in the place where a 15A should be so something further up line blew. Only thing is none of fuses under the bonnet are marked for what they do. I have lost wash/wipe function, the "on" lights for the heated rear window and air con, the radio thinks the car is off so therefore turns itself off after 30 mins or so (does the little bleep bleep thing), does anybody know which fuse would have blown?
Ian
Fuses!!!
- WebCode
- Rally Driver
Re: Fuses!!!
There is an extra fuse located behind the OBD connector panel.. The panel is located at the top/front of the centre consul.. It will prise of with a little difficulty
Re: Fuses!!!
Thanks for that, I removed the panel at the front of the consol, there was no fuse just the diagnostics socket. Any ideas?
Re: Fuses!!!
yuyotuiie - Thanks for the help, works well
Seriously does anyone have any idea what fuse is what? I have looked under the panel behind the disply and no fuse. Help!
