Steering Wheel shake?
RussMarc
Postby RussMarc » Tue Jul 15, 2008 6:48 am
My car is a 55 plate Megane 1.6 vvt, can anyone tell me what might be causing my steering wheel to wobble whilst driving? This happens at around 50-60 MPH whilst driving on the motorway. I can feel it shaking, if you momentarilly let go of the wheel you can see it wobbling from side to side. I've not checked my tire pressures for around 2 weeks so I might check that first. This appears to be intermittant but lately I'm beginning to notice it more over the past couple of days.
Thanks for reading this.
Russ.
markren2004
Re: Steering Wheel shake?
Postby markren2004 » Tue Jul 15, 2008 11:10 am
steering wheel shaking at particular speeds usually means the front wheels need rebalancing, or maybe even a loose wheel, or somthing has failed in the steering/suspension area.
you need to get it looked at.
nickbell69
Postby nickbell69 » Tue Jul 15, 2008 3:52 pm
I'd get the front wheels balanced first. Take it into any tyre place avoid the likes of kwik fit/ats etc as a small independant will do exactly same thing and not scare the living daylights out of you by telling you your tyres need replacing and brakes are on way out!! ;-)
Users browsing this forum: Google [Bot] and 57 guests
