The Dashboard Display will not light up at all
When starting my Renault Scenic Meaganne 1.9DCI none of the dashboard display will light up at all, no speedo, fuel, trip computer, clock or indicators. etc
Renault say it could be a cluster problem and would cost £400 to supply and fit. Any one else had this problem and can advise?
They Say its an Instrument Cluster
Steve
Steve
- BurntCarcus
Yes got mine sorted at Renault, the Part was £390 then labour on top cost me £483.00 in total and only took them just over 1 hour to fix. I could have got a reconditioned part for £50 but they would not fit it.
Be aware though they cannot put the mileage back to what it was, it gets reset to 000000. i complained about this but there was nothing they could do, so i insisted they stamp the log book with the present mileage etc
Steve
Steve
Thanks for that Steve, I think it's out of order that they refused to fit a rconditioned part - it's your car after all!
I've just got mine back from my local garage:
They've cleaned up the dirty contacts at the back of the dash and now all is back in full working order, including mileage counter. Cost £100.
Thanks for the info,
Jaqui
Jaqui
Re: The Dashboard Display will not light up at all
I get this intermittently on my Megane (07 plate 1.5 DCi 105hp). The time-honored helpdesk technique (switch off and switch on again) fixes it. If it happens again I'll take it to the dealers.
"sans illumier, Rodney".... as they say in Peckham....
Liberté, égalité, fraternité
- Currently Drives:: Renault Scenic Dynamique 1.9 dci
Re: instrument panel
walibe wrote:Which phase of Scenic? or a year will do.
my 53 plate scenic is doing the same except it comes on after a good run, but all my display has been reset.
My mileage reads 13000 mire than before. help.
- renault37
- Currently Drives:: Megane 1.9 dci privilege
Ino this is an old thread but the only one i can find!!!
My 2004 dci megane's milage display has started acting up this morning on my way the work it had gone black and didnt show a thing so when i got to work i turned the car on and off and it came back on showing
Press the clutch or brake to start. It then went to the oil level as noral nd it came to the message screen saying auto lights deactivated and usual. But if i press the stalk it will not move and just stays on the message
Good day, I have a problem with my Renault Megane 1.9dci not starting up. When I insert the card and start all other lights are showing up, but the engine light does not show up. The engine is turning over nicely, does not end up staring at all.
Could you please assist!
Users browsing this forum: Google [Bot] and 104 guests
