Which Iridium to choose?
Hi guys, a quick one here..... which is the best iridium plug to fit, NGK or Denso?
I found them on eBay as they are not available locally. NGK plugs are aroung GBP25 set of four, while Denso are GBP35. NGK are 0.6mm while Denso are 0.4mm..... got confused now!!
Help please
Help please
Has anyone out there tried the Denso plugs? is it an advantage to have the tip smaller than the NGK plugs?
The NGK's tip is 0.6mm, Denso's is 0.4mm. Any ideas?
- xirc0m
meganeboy wrote:Has anyone out there tried the Denso plugs? is it an advantage to have the tip smaller than the NGK plugs?
There is no direct part no for Denso to be use for Renault M2... which means u got to Re-Gap it... and I would not recommend it...
I do have some guys I know who use it and complain...
NGK for far no problem
The man of knowledge must be able not only to love his enemies but also to hate his friends.
Friedrich Nietzsche (1844 - 1900)
xirc0m wrote:The exact part no . BKR6EIX
Been using it and sold a couple of it to fellow M2 owners in Singapore... its a 0.9mm gap... more responsive...
Part no. quoted by the supplier (and site) is BKR6EZ for the NGK IX plugs.... can anyone confirm this pls?
- xirc0m
meganeboy wrote:xirc0m wrote:The exact part no . BKR6EIX
https://www.ngk.de/index.php?id=659&pd=6 ... M%E9gane+2
https://www.ngk.de/index.php?id=660&test ... erzen/8897
https://www.spark-plugs.co.uk/cars/renault.htm
Hey guys.....
Just changed the standard plugs to NGK Iridium and I can say they do quite a difference on the car's performance.... it feels much better, idling is smoother, and accelleration feels better too.....
While messing around with the car, I also took the bumper off and replaced the standard bulbs to Osram SilverStar. I noticed that I had one of the headlamps loose from the bottom and after re-installing everything went for a test drive and I can say that the small banging sound I used to hear from the front went away. Turned out to be this loose headlamp!
Quite happy now. Any idea if aftermarket ignition coils would further improve the performance? was having a look at these :
https://www.beru.com/english/produkte/pr ... ur+(KM0/1_)&typ=1.6&ktypnr=17731&action=step04
Tks to all
Tks to all
- xirc0m
meganeboy wrote:Hey guys.....
Tks to all
Cool ! Beru Ignition Coil...
- How much issit selling @?
- Whats the diff. compare to Stock Ignition Coil?
xirc0m wrote:meganeboy wrote:Hey guys.....
Tks to all
Just got a quote from https://www.sparkplugs.co.uk for the Beru Ignition coils. They sell at £20.02 + VAT each + shipping.... not that bad at all!!
Users browsing this forum: Google [Bot] and 28 guests
