Gear Knob
- Meggyman
- Currently Drives:: 56 Megane CC 2.0 Privilege in grey.
Full leather etc
Gear Knob
Why is the Megane gear Knob so easily marked.
Have a fiesta too and it stands up to the rigours of daily life much better than the Smegane all round.
Renault state a new Knob is approx £40 for a replacement, and you can't just buy the easily marked top piece. You have to buy the whole knob.
Other than that I am so damn careful to the point where I hardly touch any part of the interior for the fear of marking or damaging anything.
Megane 53 plate 1.6 VVT Dynamique.
- the big yin
- soterman
Mine is slightly scratched and the numbers have slightly faded.
I am within the warranty period and I have enquired at 2 dealerships. The answer I got was the same (dealerships are 240km apart): 'Sir, you have sweaty hands and the top bit was not designed to withstand this kind of treatment'
Well I knew that beforehand! Both said that they will not replace the knob, as that would be 'normal wear and tear'. Phoned at Renault's centre office in Athens (just for the fun of it), and yes the answer was the same - normal wear and tear....
'05 1.6VVT Megane II[/color]
- Megane II
- Currently Drives:: Renault Megane II 1.6 Dynamique.
K&N Filter
Bilstein B6 Suspension
Megane RS springs
Toyo R1R
Pioneer 8200BT - Location: Athens-Greece
soterman wrote:Mine is slightly scratched and the numbers have slightly faded.
They have changed mine under warranty.
Michael Schumacher.
7 times F-1 World Champion.
gear knob
I have had 2 replacement gear knobs both under waranty. Renault are aware of this problem but are failing to address it. My dealer has been onto them for seven months now and still they dont want to find a solution..
Speed is only relevent if you pass some one
- scoop
Gettin mine replaced on Friday under warranty along with bottom ball joint which failed on first MOT. Pays you to go to a dealer for your first MOT test, I was suprised it was covered but there you go!
Kind Regards
Scoop
04 Megane Dynamique 1.6 VVT 16V / Cherished plate / In Black 5 door / Lexus lights, Mint!!
"Shut Ya mouth and give Ya Arse a chance"!
Scoop
