Hi all,
I have recently hardwired a nextbase dash cam into the internal fuse box in the passenger footwell. To get it to work I need to earth it on some metal but cant see anywhere close apart from the door but this will trap the wire when the door is shut. Does anyone have any ideas when I can do this. Cant find any metal or anyway to feed it to the bonnet.
Earthing Point
- Currently Drives:: 2008 Renault Megane
Re: Earthing Point
there is a good earth point just above the fuse box between fuse box and door seal..
- Currently Drives:: 2005 Renault Megane II Dynamique 1.6L 16v
Re: Earthing Point
You can use an existing nut/bolt as there're a fair few tucked up away on the bulkhead.
- Currently Drives:: Mégane mk2 1.5dci 2006
Fabia Greenline 1.4 DCI 2008 - Location: Thanet
Re: Earthing Point
Hi, not sure if you're still about. Can I ask if you have a dab radio? I did the same as you, but the camera interfered constantly with the radio reception. Eventually had to take camera out. Did you have same prob? Thanks
Users browsing this forum: Bing [Bot] and 39 guests
