Hello guys i bought 2004 1.9dci 88kw Megan 2, driving home from oil change i noticed that the AC, regular cabine fan, whiper splash, rear heated glass, and cigarete lighter doesn't work.I search on forum and i found out that radio fuse 15A under dash is for all above expect heated glass, i pull it out and it was good, but i change it and nothing happened still nothing above worked.Do somebody know what i shoud do next?
Thanks a lot
Radio fuse
Re: Radio fuse
make sure you check the right fuse as in this video clip
https://www.youtube.com/watch?v=_-xD7AEWeVo
Re: Radio fuse
scooper1000 wrote:make sure you check the right fuse as in this video clip
I changed right fuse, now electronic fault displayed i cleaned ucp modul and connectors and im thinking about buying new one
- Currently Drives:: Megane cc, Ibiza cupra
Re: Radio fuse
If you have a volt meter test if you have power going to the fan fuse in the glove box. Top right fuse. Just remove it and connect the volt meter. If nothing then the wire powering it is fried.
Taken me a couple of weeks to find the issue. You’ll find your brake lights ain’t working as well so be carful.
Users browsing this forum: No registered users and 64 guests
