sounds like the pressure switch.
If you're going to hot wire the clutch, use similar wire to what's going to it now and use a fuse.
Bob
ps search on line about by passing 3 wire switch, someone's probably done it.
wiring diagram
Re: wiring diagram
You can only remove that code with a renault clip or a very advanced one, the cheap clips wont be able to read or reset that issue.
I wouldnt suggest you to run the compressor directly from the battery because i am pretty much sure you have the same problem like me, that pressure sensor disables the compressor if you have less ac refrigerant in the system or if someone overfilled it, thats what renault told me.
What i did was, i ordered a pressure sensor on ebay for around $15 i replaced it on my own tried to clear the code with a random obd code reader but it didnt even show it, then i went to an official renault dealer and they plugged it in read for error codes it showed the ac as disabled, they enabled it and it worked like it should after that.
Good luck!
Good luck!
- Currently Drives:: renault megan dynamique 2006
Re: wiring diagram
kush wrote:You can only remove that code with a renault clip or a very advanced one, the cheap clips wont be able to read or reset that issue.
Good luck!
I see so pressure sensor disable the power to the ac so that explains the power issue..So just order new sensor then get that code reset and hopefully get it sorted,many thanks everyone
Re: wiring diagram
Thats what renault told me and it worked.
How i understand it is if the sensor is working and there is gas leak or overfill it will shut down the power to the compressor so it doesnt cause any damage. But also the other thing is if the sensor itself has an issue or gets broken it gives fake information to the ecu so it shuts down the power because it thinks there is an issue.
Before i replaced the sensor i tried enabling the AC with the renault clip but it didnt allow us, but after i put the new one in place it worked like a charm.
Good luck!
Good luck!
Re: wiring diagram
Good luck!
just been on youtube and you can reset codes in ecu by disconnecting battery for 3o mins.
Re: wiring diagram
You can get away with wiring it direct via a switch of course BUT when you come to lights or stop the revs will drop dramatically because of the compressor working so you will have to stop it working when you stop but should be fine on the motorway for example
