Hello
I'am a new Megane II CC 1.6 113Hk owner. love the car. But i have a little problem with the car. sometimes when i start the car it wont hold revs, and need some help, me pressing the speeder. i can't see any pattern when it fails to hold rev. it apears 1-2 times out of 14. i have read that the thottle body needs cleaning, and that is the job for the weekend. my question is, is it nessasery to calibrate the throttle body after i have it disassembled? and is it posible to do without special dealer equiment?
picture of my new car
https://lh3.googleusercontent.com/m352l ... 59-h944-no
Megane II 1.6 113Hk throttle body
Re: Megane II 1.6 113Hk throttle body
Disconnect the battery before you do it or you could lose a finger, the throttle opens every few minutes I believe when key in.
After cleaning simply start the car and let it idle it will relearn.Don't rev it.
It may be a bit rough for the first 40 mile or so.
Don't forget your radio code will need reentering.
Thank you very much for the advice i Will try it Ib the weekend
I have now cleaned the throttle body, and it seems to have made a difference, when starting. but i'm still experience the rpm in idle sometimes drop to 6-700rpm but no stall, when the engine is hot. no engine fault codes . any good proposals?
700 rpm is OK at idle.
Sorry for the late reply.
Users browsing this forum: Bing [Bot] and 86 guests
