OK, so I've read a few posts on this as its quite a common problem. ABS sensor has come off its mount. I need a fix so it'll pass its MOT. What have people done to fix it on? I was just going to araldite (epoxy) it on for the MOT next week and will have the rest of the year to address the issue better.
I don't have the time nor the means to get another axle onto it.
20180106_150036 by Andrew Bilsland, on Flickr
20180106_150108 by Andrew Bilsland, on Flickr
20180106_150056 by Andrew Bilsland, on Flickr
Rear ABS mount corroded
- Currently Drives:: 2004 Megane MKII 1.5DCi (80)
Re: Rear ABS mount corroded
So I got some quick steel as it was the only thing my local autosave had. This position look OK to you guys?
https://flic.kr/p/21U9fsv
https://flic.kr/p/23gkfPH
For anyone interested in this fix...
I used Quick steel (only thing they had at my local Autosave) which is a putty that hardens like steel. And it worked!! ABS light has gone off...
20180107_123118 by Andrew Bilsland, on Flickr
fingers crossed it lasts till its MOT.
Well done
Haven't had this problem yet but read posts on it.
Will be good if you or one of us can come up with a more permanent fix in the summer.
Bob.
Bob.
grandadbobby wrote:Well done
Bob.
To be honest, I think this is the least of my problems. I noticed that the caliper was still binding to the disc when I had the handbrake off (I was still able to turn the disc though, was only some friction). Not entirely sure if this is an MOT failure, as it's only been 'little or no effort when handbrake applied'. Also, it's proper rusty in there. The tester will most likely inspect further and see my botch job.
- Currently Drives:: Renault Megane Scenic 2.0 litre diesel 2007
I have got this Problem as told by my local Garage.Ive not looked underneath the car to sort it myself but this Article gives me hope! Will crawl under car as soon as weather permits and weigh the situation up, watch this space!
PS The garage told me the disc the sensor is mounted on is not available without that half of the axle which costs a lot plus fitting!!
- Currently Drives:: megane II 1.5 dci
Hi we have finally found a soloution for this there is a comapny in the u.k who sells these items with next day delivery we have ordered 2 and they work great. here is the link to the product.
https://frenchautospecialists.com/produ ... sor-brake/
Users browsing this forum: No registered users and 59 guests
