hub ring size for renault Megane 2007 convertible
telfraser
Currently Drives:: Renault Megane 2007 cab
Postby telfraser » Sat Dec 30, 2017 10:51 am
Hello does anyone here know the Hub ring size for Reanult Megane 2007 Convertible - I putting on 4 after market 17 inch rims and need to buy some hub rings
thank you in anticipation
grandadbobby
Re: hub ring size for renault Megane 2007 convertible
Postby grandadbobby » Sat Dec 30, 2017 9:01 pm
I think you're after the adapter plates for your new wheels.
Measure the diameter of the central hole in the old wheel, that gives you the hub measurement, and central hole in the new wheel and make sure you get the bolt pattern right.
It may pay you to visit an alloy wheel specialist, even pick their brains at Halfords.
Once you know exactly what you want you could go to ebay etc.
Bob.
ps in my opinion, unless these wheels are designed to factor in the centre of gravity, they won't do your wheel bearings any good at all.
telfraser
Postby telfraser » Sun Dec 31, 2017 4:50 am
Thank you but I am after the Hub ring size I think its 60.1 but I am checking to be sure. I have after market 17 inch rims and by using hub rings I reduce vibration
Users browsing this forum: Google [Bot] and 46 guests
