Hi, I'm trying to find a switched supply under the bonnet.
I'm fitting led running lights that I'd want to. One on only when engine starts.
I thought of using the fog light supply but for some French reason the supply seems backwards? I have to use positive from battery to get any sort of negative switching?!
Is there some sort of supply that only becomes live when engine starts?
The amperage is not a problem as is negligible.
Any ideas?
I don't want to drill through bulk head if possible!!
Thanks!
12v ignition switch supply in engine bay
Re: 12v ignition switch supply in engine bay
I used something similar to this on my old clio sport tourer (estate)
https://www.ebay.co.uk/itm/New-DRL-Contr ... SwXYtYtxQN
Steve
Steve
Users browsing this forum: No registered users and 69 guests
