Clutch bleeding
Clutch bleeding
Hi all, after recently fitting a re-con engine in my 55 plate megane i was just wondering how to bleed the clucth properly? (obviously there is no resistance at the minute) All advice appreciated. Thanks.
Re: Clutch bleeding
Hi there,
don't know any more than you do, but there's a video on you tube for a scenic, see if it looks the same.
Good luck
Bob.
Good luck
Bob.
Re: Clutch bleeding
Cheers Bob I'll take a look.
Re: Clutch bleeding
Back bleed it.
Get an oil can with a thumb pump. Bit of pipe on the end and attach to the bleed nipple and pump it up to the reservoir untill no bubbles come out
Re: Clutch bleeding
Cheers craigyt, that sounds like a good idea, I'll give it a go hopefully in the next day or so providing the rain keeps off!
Users browsing this forum: No registered users and 87 guests
