Clutch bleeding
Juddy
Currently Drives:: Jaguar s type 2.7 tdv6
Clutch bleeding
Postby Juddy » Mon May 15, 2017 6:15 pm
Hi all, after recently fitting a re-con engine in my 55 plate megane i was just wondering how to bleed the clucth properly? (obviously there is no resistance at the minute) All advice appreciated. Thanks.
grandadbobby
Re: Clutch bleeding
Postby grandadbobby » Tue May 16, 2017 12:24 am
Hi there,
don't know any more than you do, but there's a video on you tube for a scenic, see if it looks the same.
Good luck
Bob.
Juddy
Re: Clutch bleeding
Postby Juddy » Tue May 16, 2017 9:40 pm
Cheers Bob I'll take a look.
craigyt
Re: Clutch bleeding
Postby craigyt » Wed May 17, 2017 8:17 pm
Back bleed it.
Get an oil can with a thumb pump. Bit of pipe on the end and attach to the bleed nipple and pump it up to the reservoir untill no bubbles come out
Juddy
Re: Clutch bleeding
Postby Juddy » Wed May 17, 2017 8:59 pm
Cheers craigyt, that sounds like a good idea, I'll give it a go hopefully in the next day or so providing the rain keeps off!
