very very smokey 2.0 turbo (after oil change)
Discussions around the Mégane 225.
19541947
Currently Drives:: megan 2.0 turbo convertible saab 9-5 auto,rover 827 auto
Hello people new member
Postby 19541947 » Sun Nov 27, 2016 6:33 pm
Hi people got a problem ,hope you can help,2005 megan 2.0turbo ,done oil/filter change now smoke everywhere,running rough when hot /warm ,as anyone had same problems cannot believe doing a oil change can cause these problems,if you can help would be great
Re: Hello people new member
Postby Stranger » Sun Nov 27, 2016 9:42 pm
Hello there, are you sure you haven't put too much oil in?
q292u
Global moderator
Currently Drives:: 2003 Clio. The Megane died.
2001 Audi A2 1.4 SE
Re: very very smokey 2.0 turbo
Postby q292u » Wed Nov 30, 2016 8:11 am
;-) Where exactly is the smoke coming from?
If you have spilled oil on something that gets hot, you will get smoke until it you clean it off or it burns off.
Just a thought, but you did use the correct oil?
Re: very very smokey 2.0 turbo (after oil change)
Postby AlexB » Sat Dec 03, 2016 12:06 am
You didn't overfill, did you?..
19541947
Postby 19541947 » Tue Dec 06, 2016 10:09 am
Thank s for reply,Will check again what you have said,What is the spec of oil to use ,normally use 5/30,many thanks
Postby AlexB » Wed Dec 07, 2016 10:37 pm
Millers 5w40 nanodrive CFS nt. The guys from Millers say it is suitable for road, just don't attempt long service intervals (longer than a year). It's ester based, cleans the engine, the nanotechnology reduces friction/wear/temperatures.
For women choose Millers 5w30 EE nano - long life, suitable for slow/short runs.
The OEM oils are listed in the Parts forum.
Return to “Megane 225”
