renault megane 120 clutch bleed control
fleetstreet
Currently Drives:: Renault Megane gt 150 gt 2007
Postby fleetstreet » Sun May 22, 2016 5:04 pm
The bleed control fits on to clutch slave cyl and connects to clutch pipe The bleed control is plastic it as 3 spring clips 1 to loch onto flud pipe the other end as got 2 clips that fits to clutch control id You put plastic pipe on control bleed valve move it till fluid flows out then push in and the clutch should work I have tried main agents scrap yards everyone i know Hope some one can help
Re: renault megane 120 clutch bleed control
Postby Stranger » Sun May 22, 2016 5:10 pm
Try posting in the wanted section too, you never know your luck ;)
