Radio code calculator.
Re: Radio code calculator.
try 9950
Steve
Steve
- Rally Driver
The code is not valid.my code generator says the number must be higher than 100
I have two different generators
my first one said had to be over 100
second one put out a code
Steve
Steve
- Rally Driver
where did you get the one that gives the code please
- Currently Drives:: Renault Megane II Grandtour 1.6 16V
freelanderuk wrote:where did you get the one that gives the code please
I have two Android apps (code generation for free)
Renault Radio Code Calculator from jmt products can handle Serial lower than 100.
Greetings from Berlin
RollingPants
- Rally Driver
If you use Android, I would recommend Renault Code Scanner, which is a free app. You only need to scan the barcode on the side of the stereo unit and it will immediately generate the appropriate code.
Hi there can anyone help me I've tried everything on here and can't find any of the links. Just bought a megane and it needs a radio code (previous owners disconnected battery for some reason). Would anyone know where I could find one there's no service book!
renault megane 1.4 oasis
8200483757T
Thanks in advance
8200483757T
Thanks in advance
- Rally Driver
Hi can someone generate code for my radio please... Security H066 Thanks
- Currently Drives:: Clio 1.5dci x 2
Megane Convertible 2.0dci
Fiat 500 1.4 lounge
Scenic II 1.5 DCi
Scenic II 1.4 Facelift model
Ford Ka but we musn't talk about that........
Hi
I've got the security code Y153 for mine but the app says FAIL..... Anyone want to try this in their app?
Sikot2, yours is 4925
K
K
- Rally Driver
Fiat 500 1.4 lounge
Scenic II 1.5 DCi
Thanks. Thats working.
Hi guys just got myself a megane and so far so good sorry for going straight in with a question but I need a radio code
Have a pre code of M293
Mark
Mark
1550
Steve
Steve
