Aircon problem
sonjadalton
Aircon problem
Postby sonjadalton » Thu Oct 18, 2012 5:53 pm
Hi all,
This just happened. My aircon doesn't work, all the dashboard lights are working (check photo)except the display panel one where you see the temperature and fan indication. It wont work at all, with the cold mornings I need air to clear my windows. Has anybody got a solution?
Its a 2006 Megane station wagon
sonjadalton
Re: Aircon problem
Postby sonjadalton » Thu Oct 18, 2012 7:22 pm
Just checked, the cigarette lighter doesn't work, the windshield spray neither and the radio does not switch off when opening the door
freelanderuk
Re: Aircon problem
Postby freelanderuk » Fri Oct 19, 2012 4:54 am
i would check the fuse box for the corresponding fuses and check they have not blown
Drive it like you stole it
My flickr
sonjadalton
Re: Aircon problem
Postby sonjadalton » Fri Oct 19, 2012 4:04 pm
Took it to a Renault dealership today, he didn't have much time as he was busy but he doesn't know what the problem is. He's sure its not a fuse though. He said it might be water damage or a break in the wiring. Made an appointment for next Wednesday for him to look at it closer , so unless I find an answer on here I'm broke until Christmas :cry:
freelanderuk
Re: Aircon problem
Postby freelanderuk » Fri Oct 19, 2012 5:22 pm
I am sure that I read some ware that the CIG lighter and radio and possibly other things are on the same fuse,
Its easy enough to check your self before you go to the stealers
My flickr
sonjadalton
Re: Aircon problem
Postby sonjadalton » Mon Oct 22, 2012 11:40 am
The dealer checked out the fuses, nothing wrong there :cry
Deejay2
Currently Drives:: Renault Megane 1.9 dci 2004 manual 5 door hatch
Re: Aircon problem
Postby Deejay2 » Thu Nov 08, 2012 11:48 am
Symptoms were the same on mine but the aircon was totally dead, none of the lights came on, radio and cigarette lighter also the same as yours. Replaced the 15 amp fuse in the glove box compartment fusebox, second from the top, middle row. Replaced two days ago and still working fine.
morganjake1544
Re: Aircon problem
Postby morganjake1544 » Thu Nov 08, 2012 7:40 pm
http://ray-lee.co.uk/megane/dialogys/MR364MEGANE8.pdf
See page 46, fuse 'G'.
(G) 15 A Radio - offset display - headlight washer pump relay - first row cigarette
lighter
- heated seats - screen washer pump - diesel fuel heater relay -
air conditioning control panel - AC control unit - auto-dimming rear-view
mirror - Protection and Switching Unit
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 186 guests
