screamer pipe anyone??
sultantariq2509
Currently Drives:: Megane dci
Postby sultantariq2509 » Fri Apr 06, 2012 1:55 am
Anyone fitted a screamer pipe to a deseil?? Wanted to know rough price and if able to do mysf.
Re: screamer pipe anyone??
Postby joeishmather » Fri Apr 06, 2012 8:58 pm
What is a screamer pipe?
deano469
Postby deano469 » Sat Apr 07, 2012 7:43 pm
joeishmather wrote:What is a screamer pipe?
I think Instead of the Turbo wastegate dumping the boost back into the exhaust pipe, a seperate pipe is run from it so the Turbo noise is a lot louder.
Postby joeishmather » Sat Apr 07, 2012 9:02 pm
A dump valve?
Postby joeishmather » Sat Apr 07, 2012 9:03 pm
I gave thought about doing this, but apparently it's quite expensive as the aftermarket dump valve has to be welded on.
Would also be interested if there was anyone who's done it tho.
deano469
Postby deano469 » Sat Apr 07, 2012 9:24 pm
joeishmather wrote:A dump valve?
No, the wastegate regulates the pressure the Turbo puts out, once the correct pressure is achieved it dumps the excess into the exhaust. A dump valve releases the pressure from the boost pipe work to stop it stalling the compressor wheel when you let off the throttle.
Postby joeishmather » Sat Apr 07, 2012 9:36 pm
Ah, so is this 'screamer' a easier thing to fit? Im interested in this now, never heard of this before...
sultantariq2509
Postby sultantariq2509 » Mon Apr 09, 2012 4:49 am
Im not sure how its done but quite a few cars in bham hav got them on. Ive heard it on a 525d and a golf tdi.sounds sorta like r32 or s3 exhaust.
Users browsing this forum: Google Adsense [Bot] and 25 guests
