Anyone have an aftermarket headunit?
Postby joeishmather » Sat Aug 27, 2011 8:33 pm
hi, i have just bought a sony head unit and want to be able to use the steering controls anyone give me info on how to do this?
i know i need a patch lead or something and then another cable thing, also i dad a update list radio prior to this one so i want the screen to work, apparently the car has can-bus..
anyhow any advice or experience would be appreciated.
thanks
Boomstyliemikey
Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Re: Anyone have an aftermarket headunit?
Postby Boomstyliemikey » Sat Aug 27, 2011 9:01 pm
you need these 2
https://www.ebay.co.uk/itm/RENAULT-Sceni ... 214wt_1139
https://www.ebay.co.uk/itm/Connects-2-SO ... 678wt_1139
you wont ever get the clock screen to work tho
fairly simple to do. If i can do it you defiantly can
Postby joeishmather » Sat Aug 27, 2011 9:11 pm
thanks, do you have these parts?
is there more to it than just directing one wire to one plug sort of thing, is there some circuit in it?
reason im asking is, it seems alot to me and i was wondering if i could just chop and direct the wires myself... im fairly good with the electronics and things, ive managed to fit cruise control with all original parts so hoping it cant be anyomre difficult than that.. unless there is a circuit of some sort..
thanks again
Postby joeishmather » Sat Aug 27, 2011 9:13 pm
also notic that first lising says they give a free patch lead, you just have to tell them which one, so that saves getting the second item i guess!
peter h
Currently Drives:: Renault Megane 1.6 VVT Dynamique Auto
Postby peter h » Sun Aug 28, 2011 7:56 am
chopping and changing id a nightm,are, i considered it.
the adapter and patch lead takes 5 mins.
also althou the screen doesnt work on dash, mine comes up with RENAULT time and temp.
which head unit.
Boomstyliemikey
Postby Boomstyliemikey » Sun Aug 28, 2011 10:14 am
Dont start chopping the wires up. Peter is right its not worth it. I tried doing it thinking tI would save me money but you need the interface wire. The interface wire has a box in it which translate the stalk signal to something the head unit can understand. Without it the head unit controls wont work. I've experienced the frustration of trying to splice the wires together myself and it not working.
Yeah ive used this and it works fine. I got mine second hand off ebay for £20 so quite cheap
Postby joeishmather » Mon Aug 29, 2011 4:27 pm
im not sure if itd be right... there only £10 new, so just going by price but as the other thing is 3/4 times as much i cant imagin it being the right part... have you used it?/what did you use it on/with??
thanks
Boomstyliemikey
Postby Boomstyliemikey » Mon Aug 29, 2011 8:16 pm
[quote="joeishmather"]im not sure if itd be right... there only £10 new, so just going by price but as the other thing is 3/4 times as much i cant imagin it being the right part... have you used it?/what did you use it on/with??
thanks[/
Eddies is a different brand. Auto leads if I'm correct. The one i have is connects2. They are usually about the same price so would question if that is all you need to get the steering wheel controls to work for that cheap.
