Language on Dash
- Currently Drives:: 1.5 Megane tourer estate
Language on Dash
Is it possible to change the language from Spanish to English on dash?
- Ray
- Site Admin
Re: Language on Dash
don't believe so. don't know if Paddy can provide an answer from CLIP
yep, its possible via CLIP and also by other EOBD scan computers.
Thanks for the replies chaps but what is CLIP & EOBD and can I do it myself.
CLIP is the computer that the Renault dealers have to connect to your car.
Other OBD machines is similar computers but designed to be universal, for all the cars. If you have this kind of computers you can do it yourself
Again chaps thanks for your help, car going in tomorrow to have the language change, I hope.
I think I go with the the "i can do it myself" if it may cost me much to go Renault dealers.
to go to the DIY is a little bit high rated...it requires that universal machine or CLIP. the cheap ELM327 i supose it will not change that settings because that setting requires access to change setups on the ECU, ELM327 doesnt do that as far as i know...
good luck
good luck
Have had the language changed at last, done by a renualt dealer, cost 10 euros, about £9.50ish.
Users browsing this forum: No registered users and 66 guests
