Standard head unit with active amp.
Postby Paddy » Wed May 11, 2011 9:55 pm
Can some one point me to the guide that explanes the kit required for installing a sub with the standard headunit.
Ta,
Re: Standard head unit with active amp.
Postby joeishmather » Wed May 11, 2011 10:54 pm
I have one with mine, basically the amps normally take a low input, you can get something which you wire inline with the rear speakers on their way to the amp (if you take the feed from the rear speakers) which converts the high feed from the normal hu to low.. You can buy the thing from halfords, like a fiver I think, I have one on mine.. Hope that makes sense..
Postby Paddy » Thu May 12, 2011 10:15 am
Thanks lad,
Do you lose the rear speakers? Ie is it either or?
Postby joeishmather » Thu May 12, 2011 11:01 am
Nope just splice off the wires, in otherwords the wire goes to the rear speakers but also you tap into it and that goes to the amp... Like a t piece ( if you were plumbing)lol
Postby Paddy » Thu May 12, 2011 1:10 pm
joeishmather wrote:Nope just splice off the wires, in otherwords the wire goes to the rear speakers but also you tap into it and that goes to the amp... Like a t piece ( if you were plumbing)lol
Yea get you.
Next question at the rear of the head unit what colour wires need to be spliced, which colour go to either of the rear speaker?
Ta
Postby joeishmather » Thu May 12, 2011 2:50 pm
Can't remember off hand, you can always splice them in the back of the car tho..
Postby Paddy » Thu May 12, 2011 4:09 pm
joeishmather wrote:Can't remember off hand, you can always splice them in the back of the car tho..
Any chance you could take a look? Please!
Postby joeishmather » Thu May 12, 2011 4:21 pm
Yeah no problem I can sort it for you! :-)
Is it a 3 or 5 door?
And in return recon you can activate my cruise control? ;-)
Postby joeishmather » Thu May 12, 2011 5:07 pm
One way to tell would be to play music clip some wires n see what happens... Perhaps not the best way but it is one way to find out, I'll have to check my note book thing when I'm home for the wire diagram..
