Renault megane 1.6 2003 daynamic vvt fuel filter position?
linux44
Postby linux44 » Thu Dec 25, 2008 1:48 pm
can an one tell me is there is an fuel filter on megane 2003 ,if so where is it
cause i have looking for it and spend more than 2 hour under the car and still couldnt fint it
help please?
sav0
Currently Drives:: Megane 1.5dci 53 Plate
Re: Renault megane 1.6 2003 daynamic vvt fuel filter position?
Postby sav0 » Thu Dec 25, 2008 6:54 pm
if you take the drivers side front wheel liner off you will see it
WebCode
Postby WebCode » Sat Dec 27, 2008 2:16 pm
The filter is in the Tank and forms part of the fuel pump assembly..
It is supposed to be replaced every 72K.. However the big risk of removing the pump is deformation of the pump collar thread, which at worst case will require a replacement fuel tank..
Fuel tank deformation (plastic tank) is not an uncommon problem on renaults. My advice is leave it well alone..
