Engine Additives
defer_dog
Currently Drives:: 1.9 DCI Megane
Engine Additives
Postby defer_dog » Sun Dec 07, 2008 11:55 am
hello everyone im new to this so bear with me
on the little screen on the dash board it says check injectors if i use the engine additive redex could it clean my injectors enough to get rid of this light?
also is redex the best??
WebCode
Re: Engine Additives
Postby WebCode » Sun Dec 07, 2008 9:58 pm
It will actually say "check Injection".. This is a generic message and is not specific to the "injectors"..
Only a Diagnostics check will confirm the fault.. I guess this is a Diesel? in which case I would suspect 1 or more defective glow plugs as the likely problem..
