Morning all,
hope you can help me in time today....
Long story short, may be getting ripped off from a garage and need to know the firing sequence of the cylinders from left to right so essentially I know which plug goes into cylinder 3.
Cheers all
Fin
Firing Sequence Of Megane 2 1.6 2003
- WebCode
- Rally Driver
Re: Firing Sequence Of Megane 2 1.6 2003
The firing order is 1342. with cylinder 1 being at the flywheel end..
Note however this engine use "wasted spark" ignition. That means that the the plug fires twice in the 4 stroke cycle. Once on the compression, and then again on Exhaust..
Cylinders 1 & 4 are connected as a pair as are 2 & 3...
Cheers webcode
Turns out the garage the wife took it to "accidently" put the original faulty coil back in ....
- WebCode
- Rally Driver
Nice...
