Electrical Problems...Going from Bad to Worse!! Help Please!
si1980
Currently Drives:: megane II '03
Postby si1980 » Wed Sep 17, 2008 4:43 pm
Hi All
Megane II - '03 plate here.
It's suffered with electrical problems before - electric windows which was allegedly fixed by Renault a few years ago... a few years go by and all was well.
Now over the past few months many problems have arisen, here's what I've got and how long it's been happening:
1) electric windows at best are intermittently working - past 3 months
2) Abs + STOP light + Warning light + Service light are all ON - past month
2) 'Steering not locked' message on dash when locking the car - past week
4) Airbag light has now come ON - past two days
5) n/s indicators flashing at double speed - started today
6) n/s/f indicator not flashing at all (bulb is fine) - started today
7) ...what's next!
- I've checked all fuses in the engine bay fuse panel and cleaned them - lights remain on & problems remain.
- I've tried the 'wiggle test' on all wiring looms I can get my hands on - lights remain on & problems remain.
- I've 'rebooted' the thing (disconnect battery for 15 mins) - lights remain on & problems remain.
Can anyone advise on what to do next please?
TIA
WebCode
Re: Electrical Problems...Going from Bad to Worse!! Help Please!
Postby WebCode » Wed Sep 17, 2008 5:49 pm
Sounds like water in the UCH.. The (UCH) fuse box is located on the passenger side of the engine bay.. There was a modified cover fitted to stop this happening.. Very common and one time on early vehicles.. Also expensive to buy a new one..
si1980
Postby si1980 » Sat Sep 20, 2008 10:20 am
thanks for the reply
yesterday the problem got worse - in addition to all the existing problems mentioned above - I was 2 hours away from home and the car failed to start when I pushed the 'start' button - again another electrical problem...Had to call the RAC and get them to bump start me, and then pray that I didn't stall it on the way home.... I eventually get home, stop the car, hit the start button and it decides to start first time !
there is a big cable loom to the right (and sort of in-behind) the battery - anyone know what this is doing? I wiggled it a bit and for the first time ever, my card reader in the dash lit up! starting to think there could be a problem with this loom?
also does anyone know how to get the dash cover off to get at the card reader? I have a feeling the card reader has slipped as the card won't go into the slot properly....
any help much appreciated as I'm really struggling with this.... thanks all.
