Auto Lights
iaina
Currently Drives:: Megane 2, 1.9DCI Expression
Auto Lights
Postby iaina » Thu Apr 07, 2011 8:28 am
My auto lights come on even when the light levels are quite high, in other words unless the car is in bright sunshine. also once they are on they do not extingush even in bright sunshine. For the moment i have switched them off altogether. any ideas on how i rectify this? I have made sure that the windscreen in front of the sensor is clean.
Regards Iain
I only drive this because it is fun!!!
Re: Auto Lights
Postby Stranger » Thu Apr 07, 2011 9:59 am
Check that the sensor is firmly adhered to the windscreen and that there's no damage to it, I've heard that either of these can cause issues.
iaina
Re: Auto Lights
Postby iaina » Thu Apr 07, 2011 11:25 am
Thank you I will check. Iain
iaina
Re: Auto Lights
Postby iaina » Thu Apr 07, 2011 4:16 pm
Spot on answer, The sensor behind the interior mirror had come unclipped from the main housing, although without actually pushing on it i would not have realised it was not as it should be, it just clicked back into place and now my auto lights work fine. Thank you. Iain :D
Re: Auto Lights
Postby Stranger » Fri Apr 08, 2011 6:58 am
Result :D
