HI JUST HAD TO REPLACE MY NEARSIDE INDICATOR BULB AND FROM THE RECENT BLOGS MOST OWNERS FIND IT VERY DIFFICULT,WELL PROBLEM SOLVED,REMOVE THE TWO PLASTIC CHASSIS COVERS ABOVE THE HEADLAMP,THEN REMOVE THE BATTERY MAKING SURE YOU HAVE THE RADIO CODE.ONCE THE BATTERY IS OUT YOU CAN SEE ALL THE LAMPS WITH THE EXCEPTIOM OF THE INDICATOR.YOU CAN REACH IN TO THE LAMP HOLDER AND THEN TURN IT ONE QUARTER TURN ANTI CLOCK.ITS A BIT FIDDLY BUT BEND THE TURN FIN TOWARDS THE CENTRE OF THE CAR AND IT CLEARS ENOUGH TO REMOVE IT.REPLACE BULB BUT BEFORE YOU TRY TO RETURN THE LAMP HOLDER TO THE HEADLAMP "TRIM A QUARTER OF AN INCH FROM THE TURN FIN" AND YOU WILL FIND YOU HAVE NO PROBLEM REPLACING IT. THE TURN FIN THAT EXTENDS FROM THE REAR OF THE LAMP HOLDER IS TOO LONG AND GETS TRAPPED AGAINST THE CHASSIS..HOPE THIS HELPS
