I had this message in my dash.
I replaced the battery.
The message remains on every start up.
Anyone know the rest?
Regards,
REPLACE BATTERY message.
- IainMW
Re: REPLACE BATTERY message.
My Laguna tells me when the keycard battery is low (but it says Keycard Battery Low)
It also flashes up "Battery Low Start Engine", usually when I have been using my 12v electric tyre inflator or if I have been litening to the radio without the engine running. It then displays "Battery Charging" for the next 6 or so miles.
I have had the battery checked and there is nothing wrong with it at all?
I'd start with getting you battery tested and then try replacing the lithium cells in your key cards.
After that, Dunno?
After that, Dunno?
Re: REPLACE BATTERY (KEYCARD) message.
Sorry i should have made clear, its the key card battery. Not the car battery.
Thanks anyway Iain.
Thanks anyway Iain.
