I have a 2004 Megane and i have recently bought new lights but i am not sure how easy or how to take out the old ones and replace them with the new ones.
can anyone help please?
How easy is it to change lights?
- Currently Drives:: Renault Megane 2004
- Anthony
Re: How easy is it to change lights?
You didn't specify which lights so...
Front lights - easy if you have some basic tools. Bumper removal required.
Rear lights - very simple, no tools required.
Argggg... the lights question again. Front lights (non HID) can be done via the access cover in the wheel arches, but it's much easier if you remove the road wheel. Have a search around the forum. You don't have to remove the bumper (unless changing the fog lamps), but be prepared to spend a long time on the job if it is your first time. Be prepared to cut yourself multiple times doing it.
There are detailed posts with images for the HID models..
- Anthony
davelowe wrote:Argggg... the lights question again. Front lights (non HID) can be done via the access cover in the wheel arches, but it's much easier if you remove the road wheel. Have a search around the forum. You don't have to remove the bumper (unless changing the fog lamps), but be prepared to spend a long time on the job if it is your first time. Be prepared to cut yourself multiple times doing it.
He specifically states lights, not bulbs.
Anthony wrote:He specifically states lights, not bulbs.
