spare wheel
spare wheel
hi my megane 225 hasn't got a spare wheel was wondering though can you buy a space saver for it or is a case of buying another alloy?? i ask this because i do alot of miles and don't want to depend on the puncture repair spray.
- rjacko
Re: spare wheel
i'd try a scrap yard for a space saver or just a normal steel rim. spare on our 1.9d dynamique is a 16" std steel rim, not a space saver.
Re: spare wheel
running on the standard 18's so could u use a space saver?
- rjacko
Re: spare wheel
space saver shouldn't be a problem with 18"s. Our other car is a mondeo ST on 18" 225s and the space saver on that is only a 16" narrow space saver. had to use it before and i can see why they stick a low speed limit on using them
space saver may only be an option, ask at dealers to confirm this and if it is then hunt down one at a breakers yard as should imagine renault will charge the earth as usual.
Re: spare wheel
nothing wrong with my exhaust.
seems to have spare wheel well just nout in there apart from the jack and wheel brace, will give my local stealaship a call in the morning.
- busternlouie
Re: spare wheel
freddymercurystwin wrote:...the spare wheel space on a normal Megane is taken up with the exhaust on a 225...
Wasn't it on the old Clio 182 where the exhaust took up the wheel well space?
