Postby macmac » Tue Oct 04, 2011 3:31 pm
Thanks very much guys.
My car is doing funny things & from what I've read is exactly the same symptoms as when the egr valve needs cleaning- Very hesitant engine, like, restrictive on low throttle, it's like you can't cruise- either foot down or let off completely to cure it or it starts to kangaroo! Also, sometimes when you start it, it idles well below what it should do- approx 450 rpm when it should be about 750/800.
I've had code read at garage & it indicated middle two coils & these have been replaced with Renault ones (outer two are the updated Renault ones) It seemed OK for a couple of days but it just went back to the problems after that.
Any ideas anyone??
Regards
