hi i need a steering collum assembly and rotary switch for my renault megane f1 team 225 06 reg, can any one tell me if a normal megane 06 reg collum and rotary switch would be compatable?
Part Number: 8200 795 912- I also need a Rotary Switch Part Number 8200 216 462.
Steering Collum and Rotary switch
- Currently Drives:: Kia Cee'd 1.6 CRDi
Re: Steering Collum and Rotary switch
i highly doubt that a 1.6 steering colum and switch would be compatible the 1.6 isnt a performance motor so ur best bet would be to ask ur local dealer and get a quote then have a look online to see if anywhere sells it cheaper, then if u have a friend handy with cars ur set.
07 Kia Cee'd 1.6 CRDi
Remapped
Remapped
- WebCode
It should be covered under warranty.. Unless it has been damaged..
Do you need the complete column? If so it can be repaired by this lot http://www.bba-reman.com/ Highly recommended by me as I have used them many times..
