Megane Sports Saloon Coil overs
Cris
Postby Cris » Sun Aug 31, 2008 9:33 pm
I'm looking for a coil over kit for my '06 4 door Megane Saloon.
I was looking at KW, they have a kit for Megane, but my local dealer doesn't know which one is for the Saloon...they have the 15290010 and the 15290015 for Megane 2...my local dealer, after consulting with KW say I should use the 15290015 for the Sedan, although on their website this is for hatchback...this is also the answer received from other KW retailers...but after emailing KW myself, I received the answer that I should use the 15290010...I'm really confused now...Iwouldn't want to order a kit, and not fit my car...or are all the suspension kit the same for all Megane M's...CC, Grand Tour, Sedan, Hatchback and Coupe...?
Or if you have any other recommendations for a coil over kit, they are more than welcomed...
Anyway, anybody running on coil overs? I'm especially interested in terms of comfort...as in, is there any...? :o
Megane II - KW Variant2 Coilovers, RS front, 17" Wolfrace, Custom 2.7" Navi , Custom center 7" Monitor, Custom "iDrive", Custom CarPC DSP, Custom SQ Audio System, etc.
Cris
Re: Megane Sports Saloon Coil overs
Postby Cris » Mon Sep 01, 2008 2:22 pm
Anyone....? 1:moc
Postby Paddy » Mon Sep 01, 2008 5:19 pm
You require the 15290010
Specs are as follow:
Renault Megane Sedan - 11/2002 onwards 60-120Kw
Lowers Front 35-70
Rear 35-65
Max Permissable Axle Weight Front 1060kg and Rear 975Kg
I had mine sitting at front and rear 42mm riding on Rens 17" (Bloddy speed bumps in my area)
I had them on my last Saloon 2005, unfortunatly she is now a 1m x 1m block of scrap after sticking her into a brick wall. I shall have them again when i have the cash, nice ride.
For now its a set of Eibach on Meggy number 2
Hope this helps.
Cris
Postby Cris » Mon Sep 01, 2008 6:55 pm
Thank you very much Ulrich!!! 10x
I've also sent you a PM, asking you about the ride quality and if you happen to have a picture of your Meg on the KW's. Also, can you tell me where you got them from please?
Thanks again Ulrich!!! :)
Cris
Postby Cris » Wed Sep 10, 2008 9:45 pm
Thanks Ulrich. Can't wait to see them pics with the Saloon on KW's! ;)
