front brake caliper bolts
Posted: Sat May 17, 2008 11:25 pm
by barrie27
does anyone have any front brake caliper bolts for 1.9DCI 2003
Re: front brake caliper bolts
Posted: Sun May 18, 2008 9:16 am
by AlexB
Which bolts? Those which fix the calliper to the hub are cheap at less than a pound price. The bolt at the end of the sliding pin is expensive (a tenner), but then you may want to replace the whole set of pins, which is supplied as a repair kit. The bolts are rarely damaged and can be reused, but if the thread is damaged, then it is likely than more than a bolt needs replacement -- your safety is at stake here.
For instructions, torque values and threadlock application see the manual:
https://meganedoksi.uw.hu/MEGANE_II/MR364MEGANE3.PDF
